Small block electric water pump and heater hoses???
dusterdoug
Tracy, CA
Has anyone ever used an electric water pump and figured out a way to plumb a heater hose into it??
Example is the Moroso pump pictured here, with my projected drill and tap area.
Make a plate to go between front cover and pump and tap it there. That way you are not messing with the pump, (warrantee void if you modify it)
Lastly be sure you are plumbing to the low pressure or hi pressure side as the OEM pump would have been
