For sale is a new Howards solid flat tappet cam part # 712361. Specs are as follows:
Basic Operating RPM Range: 3,400-7,400
Intake Duration at 050 inch Lift: 254
Exhaust Duration at 050 inch Lift: 260
Duration at 050 inch Lift: 254 int./260 exh.
Advertised Intake Duration: 294
Advertised Exhaust Duration: 302
Intake Valve Lift with 1.5 ratio rocker arms: 0.540 in.
Exhaust Valve Lift with 1.5 ratio rocker arms: 0.555 in.
Lobe Separation (degrees): 108
Intake & exhaust Valve Lash: 0.026 in.
Camshaft Manufacturers Description: Lopey idle. Oval track, street/strip with 10.0:1+ compression ratio. Auto needs 3,500+ stall.
Price is $140 shipped in the lower 48 states. I will ship internationally for the additional cost.
