[FOR SALE] SMALL BLOCK HYD ROLLER LIFTER SET
blk00rt
Rating - 0%
0   0   0
I bought these and was going to go the route of an LA motor but then came across a magnum motor. I would like to get 250 for them plus pay pal fees and shipping. They will be shipped from 48328.
From Hughes website
"These are a special set of lifters that we helped to design which DO NOT require any block grinding to drop-in.
Designed for stock LA blocks and will work in Magnum blocks, these lifters will not work in aftermarket R3 blocks without additional block machining. For any application other than stock, please call before placing your order.
Lifters will drop in with heads on. (Stock iron only). Will not drop in with aluminum heads.
Made in U.S.A. by true craftsmen.
These are oil thru lifters and will oil through the pushrods if you need them to.
The oil band has been lowered so that the small blocks with the chamfered lifter bores no longer have to be sleeved.
* The lifter bores do not need to be bushed to run these lifters.
* DO NOT use these lifters with a flat tappet cam!"
