[SOLD] Small Block Mopar Parts Misc.
dam i could use that trans just so far away what year is it when was it rebuilt does it come with a converter? can you give me the rundown on it
I'd like some specs on the fluid damper. I just acquired a Magnum roller block recently and wondered if all the dampers are interchangable on the small blocks. I guess we're talking the I.D. and the engagement depths. Anyone know?
Part #720301 INTERNAL BALANCE 7 1/4 {7.250}
Chrysler A/LA 318, 340 & 360 CID V-8
6 bolt holes evenly spaced pulley pattern. May need to redrill
one hole on stock pulley. This damper is designed to be
used with a 1971 and later timing cover with the pointer on
the driver side. If it is used with the passenger side pointer,​
it will be 90 degrees off.
Thanks Stan.
Comp Cam Solid Cam w/lifters $300 + shipping
Stock oil pump $20 + shipping
904 street/strip trans $700 + shipping
Fluidampr $175 + shipping
Thanks Stan.
Stan; Wondering if the Fluidampr # 720301 is still available, if so P.M. me with some pics. Thanks, Dan.
