smallblockcuda
New Member
1. I have a 408" W2 engine that ran 10.20's in a 3000# door car. Eagle 4" forged crank, eagle rods, Diamond pistons, total seal max seal rings, Milodon pan, Comp Cams roller, New Comp lifters, Harland Sharp roller rockers, fresh. $5500.00 OBO
2. I have a set of W2 heads ported with Norris stainless steel rockers, complete with springs for roller cam, needs rocker shafts, went 10.00 in door car on 372" engine. $2000.00 OBO
3. I have a 727 with ATI 5100 converter, Turbo Action trans brake valve body, CSI carbon trans shield. $1800.00 OBO
4. I have a set of TTI 1 7/8' coated headers for A body with new Hooker aero chamber mufflers that bolt to headers. $700.00 SOLD
5. I have a 418" 340 block small block. Brodix B1 BA heads ported with T&D shaft rockers, Mopar 4" forged crank, Eagle rods, Comp Cams roller, Milodon pan, Sheet metal valve covers, with bung welded in for vac. pump, Aerospace vac. pump, with Davinci 950 alcohol carb. will separate and sell rotating ***., heads, etc....?
6. I have a powerglide with JW case and ultra bell for sbm, roller tail housing, pro brake, 1.80 straight cut gears, with PTC converter. $2500.00
