[FOR SALE] Small block, suspension, ignition, brakes, lots of goodies
CultClassik
Texas
Located in DFW, TX. Prices do not include shipping. Reasonable offers considered especially on multiple items.
2.25” stainless exhaust clamp (band, pipe to pipe) pair $SOLD
2.25” stainless exhaust clamp (lap, pipe to muffler) pair $SOLD
Erson Chrome Small Block Valve Covers $SOLD
HEI kit, includes Accel 50k volt coil, GM HEI module and diet connector - plug and play if you have a factory elec dizzy! $SOLD
73-76 A Body Upper Arms (BBJ) with new Moog ball joins and bushings, I bought them like this and didn't end up using them $SOLD
Mopar Performance Super Stock leaf springs, used in a drag car for a couple of years. These are the L and R springs rated for the lighter body (3200lb?) . Will look at them to confirm part numbers. Includes good bushings, hangers, shackles and longer Mopar Perf shocks, everything required. $150
Holley Inlet w/fuel pressure gauge port, new $15
Edelbrock/Carter fuel inlet line w 3/8” fitting, barely used $15
Comp Cams timing chain for SB Mopar, new (not a double roller like the box shows, it's a standard chain) $20
Dr Diff proportioning valve, new $30
Unknown brand lower ball joint new k781 (73-76 a body, disc) $20
2bbl Carter carb from 67 273 engine (reduced) $20
2bbl air cleaner from 67 273 engine $20
MOOG NOS lower ball joint K785 (62-72 A Body, drum) $25
Remco NOS lower ball joint K785 (62-72 A Body, drum) $25
Unknown brand Hooker style small block A body headers, not bashed in but somebody messed with one of the tubes as shown (see red marker), some weld glob on it. I will throw in a pair of collector stubs, new collector gaskets, and collector bolts (reduced) $90
A few items sold, reduced a few prices. Make me some offers and help me make room in the garage guys!
