darc1722
Trying to get this straight, a small block 318 torque converter will not require weights added to it for balancing because it's an externally balanced engine, is this true? Is that the same for a 360 or 408 stroker. In which scenario would you need weights added to a small block engine torque converter, if at all? Can someone help me understand this, thanks.
