[FOR SALE] small block turbo cam, m90 supercharger, header flanges
moturbopar
mesa az
Custom Howards hydraulic cam custom cround for a turbo aplication.
Specs are 226 at .050 intake and exhaust, 114 lobe seperation on a 110 ic. Lift is .525 int and exhaust with a 1.5 ratio rocker, .560 with 1.6 rockers. Cam is new in container. $145
I also have a low mile M90 supercharger from ford supercoupe. Very very clean.
$250
Have 1/2 thick small block header flanges. new bought for turbo headers. $60
Cam $125
$175 for the supercharger
$45 for the flanges.
Also have pro comp rpm intake New $130
M90 is a small roots style blower. The supercoupes are 3.8 litre so the blower is perfect for a slant build. I've seen them on slants at Carlisle before. Nice little units.
That supercharger woukd pull hard on a 273 with a 2.76 rear as they would never get past 4500 rpm anyway. Might need to overdrive it a bit, do your math.
if overdriven the supercharger can make about 330 to 350 hp. It would work well on a mostly stock 273 or a low rpm 318. It is rated upto 5l engine. I think it would work awesome on a slant six though.
