7duster4
I have been noticing a small spot of coolant on the garage floor. After the car sits after a drive some must leak out. But it's very little. I got under the car to investigate. The last oil pan bolt on the passenger side was wet with a drip hanging off the edge. Right beneath it was the spot on the floor. Above the bolt is the oil filter. But up top near the head it looked to be slightly wet. Whereas the rest of where the cylinder head seals against the block is dry. But it's very slight. The 318 was rebuilt a few years ago by a reputable mopar engine builder. I can't believe I would have a bad gasket. The car does not overheat or smoke at all. Can I tighten the head bolts more to see if that solves it? Or is it a lost cause? It's such a small amount at this point I'm not worrying about it too much. Last time I checked the radiator it was full. What is everyones suggestion?
Thanks for any help.
