I have one more thing I'm going to try. This was a cut to fit liner. I used my knife to remove any burrs on the cut, but I'm going to try some welding tip cleaners and see if it has any burrs I missed.
I know that. I said it already. All I was doing was using it for diagnostic purposes..23 wire might be an easy fix. You want it for lighter gauge any way though you F‘d it up withe the penetrating oil. Can’t believe you did that.
Or maybe it’s still a little long.I have one more thing I'm going to try. This was a cut to fit liner. I used my knife to remove any burrs on the cut, but I'm going to try some welding tip cleaners and see if it has any burrs I missed.
I seem to remember that. I think it was something electrical on his.
I cut it to the exact length as the one I removed, but I thought about that. I'll look at it a little closer and see.Or maybe it’s still a little long.
Made sure the new one is exactly the same as the one that was the initial problem, yeah, there may be a flaw in that logicI cut it to the exact length as the one I removed, but I thought about that. I'll look at it a little closer and see.
Like I said, I thought about that, but it welded great for years with the last liner. I'm going talk with my local welding company tomorrow. It may need a whole new gun. But I'm going to try to file the opening where I cut it first and see what that does.Made sure the new one is exactly the same as the one that was the initial problem, yeah, there may be a flaw in that logic
I dont know what they are called, but there is a tool out there to debur pipesLike I said, I thought about that, but it welded great for years with the last liner. I'm going talk with my local welding company tomorrow. It may need a whole new gun. But I'm going to try to file the opening where I cut it first and see what that does.
Burnish it with the wire. Drag it back and forth a baggilion times putting pressure 360 at the openingsLike I said, I thought about that, but it welded great for years with the last liner. I'm going talk with my local welding company tomorrow. It may need a whole new gun. But I'm going to try to file the opening where I cut it first and see what that does.
If that's like a piece of foam, there's one already on it.Probably too late for this, but I would get one for when you install your new liner.
There is no way no how a 120 volt MIG welder will make a proper weld using .045 solid wire.Good luck.
Transformer is too smallLook, what yall are not getting is this machine has laid a great looking bead with .045 before. Whether or not it had proper penetration remains to be seen. What I am saying now is it will not even attempt to lay a bead with the .035 wire in it now. It just sputters and turns the wire red. I understand what yall are saying and possibly agree, but something is ******* WRONG with the machine OTHER than having too big a diameter wire. Got it?
For aluminumJust thinking here, some wire feeds have the ability to reverse the polarity. Puts more heat on the work instead of wire.
