soft pedal
lil elephant
North Port Fl
Hey Guys:after turning the rotors, replacing the calipers and hoses , both drums with wheel cylinders and master cylinder, I still have a soft pedal. Do I have unreasonable expectations of a ferm pedal? If anybody has any thoughts on this please post. :wack:
I'd check the master possibly leaking, either out or internally. I used to plug the ports and hold the pedal to see if it goes down. Thus eliminating the other possibilities.
put a few miles on it and then readjust the rears, the radius of the shoe never matches the dia. of the drum, it takes a little wear to get the rest of the pedal to firm up.
Thanks for the advise, Ill take it for a trip and readjust the rears per your suggestion. Only makes sence! :salut:
