SOLID 66 cuda project 360 4 SPEED 8.75 REAR
snikle73
Member
Rating - 0%
0   0   0
Listing/selling for my dad, he bought this car 5 years ago in rexford montana (still has clear montana title) super solid car perfect floors frame and trunk body had one small repair on drivers rear quarter wheel lip had a rust spot size of half dollar, car has all new front end parts,new control arm bushings,strut rod bushings,rubber flex lines shocks,brakes all they way around (drum rear factory disc in front) has new runner window seals and window felts, motor is a 360 (bought off craigslist last year said to be rebuilt,has org 4 speed trans works great,org 4 speed shifter with reverse lock out,new clutch pressure plate and throw out bearing,has 8 3/4 rear end with 489 case unsure on gear ratio,dual exhaust off stock barracuda manifolds,,, we are pretty sure this is a formula "s" car it also has the 150 mph speedo and factory tach and the org tach sending unit and disc brakes, but there is no fender tag, when we bought the car it was a running driving car but it had a 318 and it was purple,when he installed the 360 he also removed the k frame cleaned and painted that also, sorry he is not looking for any trades 3000.00 cash, the car comes with all the trim,grills,etc etc, the car will need a winshield, great project for someone to finish, here are a couple pics , the doors are off in the pic and of course they come with the car and they are in great shape
WILL ALSO COME WITH BLACK BASE COAT TO FINISH THE CAR, THE ENGINE BAY,DASH AND UNDER SIDE OF DECK LID HAVE BEEN PAINTED
