[SOLD] Solid Roller Lifters
RustyRatRod
Caput villa stultus
Georgia
I have decided the solid roller in the slant is just too high of a mountain for me to climb, so I am going to sell these to help fund the rest of the car.
These are a set of very high end Mopar solid roller lifters. They are technically for a small block, but with the correct length pushrod will work for big blocks and slant sixes too. They are DROP IN for a small block and require ZERO block grinding. There are no numbers on them anywhere, which leads me to believe they are Morel lifters. They are either Morel or Crane according to my research. These have pressure fed needle bearing .750 rollers. They are all in excellent condition. They do not have much run time at all. I will take $350 shipped to the lower 48. This is a steal considering pressure fed lifters start out at about 800 dollars for Mopars. Located in middle Georgia.
