Snake
Mopar Nut
okay, upper ball joints and lower ball joints,upper bushing lower bushings strut rod bushings. the problem is when i grab the brake assembly and turn it left to right it is very stiff also and the upper control arm wants to move up and down abit and the lower arm moves back and forth a little. this is with tension on the t-bar when i remove all tension on the t-bar everything stays put and the brake assembly moves freely left to right. whats causing this binding???. the right side is fine. i hope someone has any clues to this!
