Sounds like my blinker is on but is not.
MoparMuscleGuy
Still plays with cars.
Cocoa, Fl
It sounds like my blinker is on but isn't when the ignition is on. My turn signals work and so do my hazards but this noise persists when the engine is running. The car runs fine its just this blinker noise. I figured I would ask before I dive into the problem. Thanks, MMG
Year make and model might help. I have heard some really bizarre noises from failed seatbelt buzzers.
Hey guys, sorry I didn't get back with you all. Anyway, I found the problem.
The previous owner wired his electric choke to the turn signal 12 volt source. After I pulled the wires and got a better look I figured that was the problem so I pulled the red wire from the electric choke and the blinking noise stopped:D. I just found a different 12volt source and the problem was fixed. :burnout::D. MMG
