Source for side door glass rubber seal 65 barracuda??
CANEXAN
Garland, Tx
I don't even know what it's called but on a 65 Barracuda it is located in a vertical "chrome" strip fixed to the door glass that separates the front and rear windows on both doors. There are two pieces: a channel securing the chrome strip to the glass and the other a flexible tube type thingy that bumps up against the rear window. Can anyone tell me where to get a couple of sets?
'nother question for you: I'm planning to put new "whiskers" on the doors (window wipes). I think I want to remove the windows to get at the old ones w/o damaging anything and to install the new ones. What's the trick to removing the windows? I've already got the interior panels removed and the regulators exposed. Thanks
Are you really sure you want to do that? Getting the windows aligned back up is a pita. If you roll the window all the way down you will/should be able to pry the old whiskers off and install the new ones. (I used tape on the outside door metal to not chip the paint when I removed the old ones on my wife's old dart). I'm still fussing with my windows in the convertible since they are sloppy and need to be tightened up. It seems that a roller and a bushing need to be replaced and I converted to a power motor too!
but if you really want to here it is from the 66 dart service manual.
sounds easy and it is, just the alignment is a b#tch
GLASS REPLACEMENT
Removal and remove glass from run channels.
(1) Loosen window track adjusting nuts (these are on the latch end of the door )
(2) Remove regulator arm from lift bracket channel (that's the welded track you can feel the regulator arm is hooked to on the inner door structure)
(3) Remove glass from door. (duh)
(4) Remove lift bracket from glass. (you can pry it out of the holes using a PLASTIC wedge or tool)
Before installing glass, lubricate all moving parts of the regulator
(1) Install lift bracket on glass.
~(2) Position glass into door opening.
(3) Install regulator arm roller into channel of glass
(4) Position glass into run channels.
(5) Adjust door glass. (this is the time consuming process.)
/nstallation
regulator with lubriplate.
lift bracket.
hope this helps
I'm glad you talked me out of window removal. Until yesterday I hadn't received my new whiskers so couldn't figure out how they were attached until I saw them. I've got one side in and it went really well. I really appreciate your help. Now I'm off to do the other side. Thanks again....tim
