M mey6t6 Well-Known Member Joined Aug 26, 2007 Messages 177 Reaction score 0 Location Fairmont,MN Oct 27, 2008 #1 What is the best distance the fan should be from the radiator for optimum cooling?
Johnny Dart Well-Known Member Joined Nov 30, 2006 Messages 8,948 Reaction score 4,398 Location So Cal Oct 28, 2008 #2 I believe it is from 3/4"-2".
C Charrlie_S Well-Known Member Joined Oct 17, 2005 Messages 5,290 Reaction score 3,559 Location Silver Springs, FL Oct 28, 2008 #3 As close as possible, but at least 3/4 inch, to allow for movement, and not hit the radiator. A fan shroud makes a big improvement, and if you have the room a 5 blade fan, with a thermostatic clutch.
2 Darts A-body Addicted Joined Mar 28, 2008 Messages 3,427 Reaction score 278 Location Usually in a house Oct 29, 2008 #4 Derale fans recommend fan spacing as follows: W/shroud Measure the distance from the water pump flange to the edge of the shroud and add 3/4 inch. w/o shroud Measure the distance from the water pump flange to the radiator and subtract 3 inches. Hope this helps.
O OHD Banned Joined Oct 24, 2008 Messages 73 Reaction score 1 Oct 30, 2008 #5 Electric or mech water pump?
