Sick_Six225
72 Dodge Dart Swinger
72 Dodge Dart, 225, was wondering if my spark plug should look like this? The thread has a little oil on it. Not much.
[/IMG]
That looks pretty darn good to me, and oil does collect like that on the threads.
My theory is that there is always a little oil in the cylinder left over after the rings scrape it down and this oil can't be burned off because it got caught in the threads.
Of course one would have to be sure it's not getting there from a valve cover leak or something, and soaking the threads when it's pulled out.
I don't see any oil above the sealing edge though.
Also If this motor has drool tubes, that could result in oil on the threads.
I thought if the plug had a tapered sealing surface instead of flat with a washer it does not have the tubes.
your assuming the right plugs are in it :glasses7:
OP is this a drool tube?
When I got this car it never had these drool tubes and to be truthful have no idea what they are. The guy I got the car from over a year ago said that the guy that had the vehicle prior put different heads on, mild cam, and a long tube header. I am unsure what kind of heads they are. The car runs great and has no problems I just wanted to ask to make sure that it was ok to have just a little bit of oil on the threads. Thanks everyone
As far as im tracking cast iron,
