Spark plug wires with comp headers?
LXguy
Champaign IL
Hey All:
Does anyone have a good recommendation for a set of pre-cut wires for use with the Hooker Comp headers. Looks like I need 90* boots on cylinders 5 and 7.
Any help is appreciated.
Steve
I just went with spark plug wire boots with straight plugs. I have had no melting issues. I think they are made by DEI.
I use Accel 8mm wires with 90 degree boots on all 8 sparkplugs and they work great with my Hooker headers.
90* ends and you can either run them super tight to the valve cover and up, or, loop them out down, out towards the master cylinder and up over everything. I used to route mine the second way. Used a tower off the rear valve cover bolt.
No matter the wire used, I suggest the use of a sleeve to help stop the heat and protect the wires from being burned. Those 2 cylinder 5 & 7 are a pain.
