I picked up a set of open chamber later W2s a while back and sent them to a friend that does HP cylinder heads.
Here are the flow #s fairly ported
2.08 intake 1.60 exhaust
.100" 78 cfm 62cfm
.200 153 116
.300 212 151
.400 258 182
.500 279 195
.600 281 203
Im not a head expert by any means by it appears that the low and mid lift #s are quite good, but the .500-.600 are lacking. I already have a .020 stroker 360 short block in the works that that have 0 deck flat tops with approx 6cc reliefs.
The guy who did the heads unshrouded the chambers and now that are 75cc with is a bit disturbing. It works out the compression should be about 10.3
how do these #s look? can it produce 550 hp or am I SOL
I have not picked a cam yet
.100" 78 cfm 62cfm
.200 153 116
.300 212 151
.400 258 182
.500 279 195
.600 281 203
