here are some parts that's part of a special, double secret, get ready for winter, get it off the shelf, $2.00 and $3.00 sale!
Here is a list of a number of small items for this secret $2.00 and $3.00 sale just to get rid of the stuff.
$2.00 ITEMS
2 pair of the nylon truck lid hinge shoes, SOLD
2 NIB, turn signal/4 way flasher units, $2 each
2 pair of the starter attaching suds, nuts and bolts, $2 per pair - SOLD
A pair of chrome interior coat hooks for the 64-68 Dodge and Plymouth cars
MSD plastic HEI distributor cap plug wire retainer - SOLD
Vented gas cap
2 temp senders, $2 each
Door jamb interior light switch - Pending
SB distributor hold down clamps $2 each
2 glove box door latches with attaching screws, $2 each
4 intake manifold choke well cups with new gaskets, $2 each - SOLD
Left side door handle pivot thingy that the push button activates to open the door
$3.00 ITEMS
A set of 7 jewelers screw drivers - SOLD
A single flaring tool - SOLD
Edelbrock #9135 special intake manifold bolts for the inner four attaching holes. - SOLD
90 degree fuel fitting for 3/8” fuel hose, Mr. Gasket #2966 - SOLD
SB LA intake manifold water pump by pass hose fittings $3 each - SOLD
New front wheel bearing seals for the 11” drum brakes, Sealed Power #N-17110
New front wheel bearing seals for the 10” drum brakes, Sealed Power #N-17115 - Pending
3 new front pinion seals for the 8 ¼ and 7 ¼ rears, $3 each - pending
8 ¾ or Dana 60 axle end play adjuster locking pawl - SOLD
4 Holley dual feed carb float bowl inlet fitting for 3/8” line, $3 per pair - SOLD
Pair of front wheel hub dust covers. A little rough but will work. Measures 1 ¾” diameter - SOLD
Wire strippers
All prices plus the shipping
Ken
Edison, NJ
$2.00 ITEMS
Vented gas cap
$3.00 ITEMS
Wire strippers
Ken
Edison, NJ
