Speed Bleeders sizes
hcallaway
Richmond VA
I have 74 Front Disc Brakes
and 72 Rear Drums and I want to swap out the bleeder screws from stock to Speed Bleeders.
I cannot find a good chart.
Thanks
don't bother it'll only be a source of frustration.
half the time they don't work, half of the time they only work half ***, and the other half of the time they leak.
This x1000.
Buy a pressure bleeder and never deal with the absolute nonsense of speed bleeders.
it would behoove you to check and verify seeing as different manufacturers and reman outfits all have their idea of what it should be.
And this also x1000.
The size of the bleeder has more to do with the manufacturer (or re-manufacturer) of the calipers/wheel cylinders than anything else. I've found metric bleeders on 73+ calipers.
Yeah dude, a novel idea but in reality, don't waste your time. Get a friend to help or a pressure bleeder as mentioned.
Wow! Best to check what you got for sure.
Yup. It was at least several brake swaps ago, I don't recall enough of the details to be 100% but I believe it was a remanufactured caliper. Probably had a stripped out bleeder and they just rethreaded it for metric because it was the next closest size. I know it was metric because bleeding the brakes took 3 different wrenches, one for the drums in the back and then two for the front disks, one standard and one metric. Pain in the ***.
But yeah, stranger things have happened. Just because something should be a certain size according to the book doesn't mean it actually is on the part sitting in the driveway.
