Earlie A
I ran across this issue when checking some rocker geometries this morning. When bolting a rocker shaft into the saddle on a SM small block head, I noticed the shaft wiggled (quite a bit) in the saddle. I went ahead and bolted the shaft in then checked the shaft to saddle clearance with a feeler gauge. As can be seen in the pictures a 0.0015" feeler gauge can be inserted under the shaft until it almost touches the bolt. This means that shaft side to side movement is not being supported by the saddle at all and any load in the side to side direction must be controlled by the rocker shaft bolts alone. I would think this could be a tremendous side load on a 5/16 bolt anchored in aluminum threads. Not good.
I then went around checking the shaft play in any head I could find. I checked 13 heads. 5 Speedmaster, 2 ProMaxx, 2 Trick Flow and 4 mopar iron heads. 4 of the 5 SM heads had wiggle. None of the other heads had any problems.
These 5 Speedmaster heads were purchased over a period of 2 years, so this is not an isolated incident. Be curious to know if anyone else has experienced this.
