Speedmaster Small block porting tips and results
Mopar Racers Forum
  1. MOPAROFFICIAL
    MOPAROFFICIAL Well-Known Member
    5,072
    4053
    Jun 1, 2016
    Beach
    Local Time:
    10:00 PM
    Does it Iook like the seat is smaller than where it transitions to the bowl?
  2. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    47,048
    31382
    Jan 18, 2006
    Iowa
    Local Time:
    12:00 AM
    I haven't taken mine apart yet but if they look anything like the pictures of those that have, a little valve grind and bowl blend wouldn't be a bad idea.
  3. MOPAROFFICIAL
    5,072
    4053
    Jun 1, 2016
    Beach
    Local Time:
    10:00 PM
    I didnt think you were near 190.
    Your thinking in the 2.05 getting more angles is correct. Maybe why the return of floor/ssr work was less than 8-10cfm .
    The thread should be edited down to what you do, locked and then a link thread for the discussion thread.
  4. pittsburghracer
    pittsburghracer FABO Gold Member FABO Gold Member
    2,813
    5132
    Apr 20, 2016
    Freeport, PA.
    Local Time:
    1:00 AM
    I’m no we’re near the smart engine or head porting group and being self taught has been a journey but that just doesn’t look right to me. We can rebuild it, we can make it better than before. Lol. If a snow sled rider was trying to navigate that, he would crash for sure.
    • Like Like x 1
    • Agree Agree x 1
    • yellow rose
      yellow rose Doctor of Thinkology.
      20,523
      16611
      Jun 19, 2015
      Living on the razors edge
      Local Time:
      10:00 PM
      I meant using an 82 off the bottom of your 75 if you can get it in there. Sometimes there isn't room for all that unless you go to the bigger valve.
      And I agree 15 degrees is the maximum I would use. If you can keep it down to 10 degrees all the better. If I use a back cut I try and use a 7 or 8 degree back cut if at all possible.
      • Agree Agree x 1
      • yellow rose
        20,523
        16611
        Jun 19, 2015
        Local Time:
        10:00 PM
        I doubt they could keep the TIR to under .050 if they just used the guide as a pilot if I'm getting your drift.
        I have never liked a live pilot cutting system. I prefer a dead pilot with a ball drive tool head.
        The ball drive takes up any misalignment you might have, up to a point.
      • Hemioutlaw
        Hemioutlaw Make America Great Again! FABO Gold Member
        1,221
        594
        Feb 4, 2014
        The Great State of Texas
        Local Time:
        12:00 AM
        ? Are you referring to .050 TIR on a seat that was precut and THEN installed in the head, .050 TIR is a Football field of runout.
      • yellow rose
        20,523
        16611
        Jun 19, 2015
        Local Time:
        10:00 PM
        I'm thinking TMM was suggesting that rather than use a pilot in the valve guide to machine the seats, they were somehow piloting off the OD of the guide.
        That's the was I understood his question but I could be wrong about that.
        I have seen several valve jobs with .050 TIR. They were all BBC's with 2.400 valves and .311 stems.
        Just junk crap.
        • Agree Agree x 1
        • toolmanmike
          47,048
          31382
          Jan 18, 2006
          Iowa
          Local Time:
          12:00 AM
          We don't know how sophisticated their machining centers are. If they are all cnc stuff they could machine the pockets for the seats and the bores for the guides in the same machine with a change of tooling. Just thinking out loud.
        • yellow rose
          20,523
          16611
          Jun 19, 2015
          Local Time:
          10:00 PM
          Actually, this very topic was being discussed over on speedtalk.com and I'd say most likely if SM or whoever is doing the finish work is using some form of CNC machining, I'd suspect they are using a Newen Epoch or similar machine.
          I doubt they are tooling up a CNC machine just to cut seats. Most likely they are using a regular seat and guide machine. If you are setting up to cut say 2.02/1.60 valves, you can do a 4 cylinder head in about 10 minutes max once you have the tooling set up. So I'd say floor to floor in 12 minutes per head. That's 4 heads an hour, 32 heads a day from just one machine. Doesn't sound like a lot, but it really is for just one machine. And if you have your crap together you could cut some time off of that.
        • Mopar Sam
          Mopar Sam Well Fed Member
          783
          1001
          Jul 18, 2008
          Indiana
          Local Time:
          1:00 AM
          Not me. I live less than 1.5 miles from a coal mine. Have to constantly level the machine. You would not believe how much it moves after a blast! A real pain in the rear.
          • Like Like x 1
          • skrews
            skrews Well-Known Member
            1,485
            955
            Jul 20, 2012
            Washington state
            Local Time:
            10:00 PM
            IMO a valve job with a 65° bottom cut narrowing the 45° seat to a width of .035-.040 would probably widen out the bottom cut to a more acceptable width with the 2.02 valve. The real answer as PBR has alluded to is moving to the 2.055-2.08 valve.
          • yellow rose
            20,523
            16611
            Jun 19, 2015
            Local Time:
            10:00 PM
            I agree.
            Or....................you know I'm going to say it...................a 50 degree valve job.
            • Agree Agree x 1
            • skrews
              1,485
              955
              Jul 20, 2012
              Washington state
              Local Time:
              10:00 PM
              This is probably what the seat machining looks like at SM. wham bam
            • toolmanmike
              47,048
              31382
              Jan 18, 2006
              Iowa
              Local Time:
              12:00 AM
              No wonder why you get some chatter. Thanks for the video.
            • skrews
              1,485
              955
              Jul 20, 2012
              Washington state
              Local Time:
              10:00 PM
              High capacity production line machining isn't pretty. I'd never cut seats so fast as to make that kind of heat/smoke.
              • Agree Agree x 2
              • toolmanmike
                47,048
                31382
                Jan 18, 2006
                Iowa
                Local Time:
                12:00 AM
                Me neither. I was surprised to see that. The spindle speed needs to match the feed rate. He was leaning into it pretty hard.
              • Mopar Sam
                783
                1001
                Jul 18, 2008
                Indiana
                Local Time:
                1:00 AM
                He ain't the one paying for the tooling.
                • Agree Agree x 2
                • PRH
                  PRH Well-Known Member
                  1,641
                  2414
                  Dec 14, 2018
                  So. Burlington, Vt
                  Local Time:
                  1:00 AM
                  I highly doubt if you buy the non-cnc ported SM heads....... that there is any machining of any kind done in the states.
                  • Agree Agree x 1
                  • yellow rose
                    20,523
                    16611
                    Jun 19, 2015
                    Local Time:
                    10:00 PM
                    Not a fan of the live pilot. Not sure how he is correcting the guide centering from the last head. I can promise no two heads are the same, and unless he is getting the guide level in both directions I have no idea how the tool head is doing it.
                    Especially with the live pilot. Are the guides all sized exactly the same? I doubt it.
                    Way too much tool speed.
                    Unreal. I call that junk. Now you know why most of us do a valve job when we do heads. Getting them to seal is the easy part.
                    Just garbage.
                    • Agree Agree x 2
                    • gzig5
                      gzig5 Well-Known Member
                      1,029
                      975
                      May 3, 2018
                      Mequon, WI
                      Local Time:
                      12:00 AM
                      The man has a pallet of heads to get through. And more pallets after that. Speed is money. Production is a whole different animal than blueprinting for maximum results.
                    • skrews
                      1,485
                      955
                      Jul 20, 2012
                      Washington state
                      Local Time:
                      10:00 PM
                      ^^^ unfortunate truth
                    • PRH
                      1,641
                      2414
                      Dec 14, 2018
                      So. Burlington, Vt
                      Local Time:
                      1:00 AM
                      Actually, it looks to me as though the spindle is aligned with the guide twice per seat.
                      And there’s two stages of the cutting operation..... roughing and finishing.....with a realignment between the two.
                      Also, it’s automatically varying the spindle speed during the cut to minimize chatter.
                      Pretty nice piece of equipment imo.
                    • pittsburghracer
                      2,813
                      5132
                      Apr 20, 2016
                      Freeport, PA.
                      Local Time:
                      1:00 AM
                      Well guys I’m done for now. I had a stone shatter trying to put a 75 degree bottom cut on this head. I ended up taking a sanding roll and slightly rounding the edge off at the bottom of my 60 degree cut. My valve job looks like she-ite and a swear a kindy gardner could do better with Play-doe. Would it make horsepower yes. The pinch speed is 350-300 across the entrance and it carries it well throughout the port. Even down the pushrod wall. The shortside speed is high (380-pegged 401) but is hugging the shortside curve nicely. I got to get my butt moving on my 408 build for next year so it would be a waste of needed money going any further here till I can get my local shop to do a professional 75-60-45-30-15 degree seat for my 2.05 or 2.08 valves I have sitting here. It’s times like this where I would have bought my buddies mill.
                      • Thanks! Thanks! x 2
                      • Like Like x 1
                      • Agree Agree x 1
                      • pittsburghracer
                        2,813
                        5132
                        Apr 20, 2016
                        Freeport, PA.
                        Local Time:
                        1:00 AM
                        Final numbers for now with suck-azz valve job
                        .100————71
                        .200———-142
                        .300———-202
                        .400———-245
                        .500———-265
                        .600———-274
                        .700———-282
                        • Thanks! Thanks! x 5
                        • Like Like x 2
