speedo cable 76 dart
DatDirtyDart
Member
massachusetts
looking to replace my speedometer cable, had an exhaust leak that ate way the casing, the cable that i got from autozone that said it would fit doesnt, was wondering if anyone knew the proper cable/ends to install.
318 base model dart
318 base model dart
There are 2 different ends that go to the speedometer. Beehive shaped or J hook style. Whitch do you have? Also what is the length?
I had issues at the spedo pinion, one is a smaller round nut the one I needed was a large hex nut. I had to do a lot of searching for it and finally found one on e bay.
Beehive shape up by the dash end. Large hex nut, the largest wrench I had was a 15/16 and it was larger than that, towards the trans
It's easier to swap the larger end from the old cable to the new one.
Old and new
