Speedometer Drive Gear
Daryldogs
New Member
VT
Rating - 0%
0   0   0
Greetings, I'm in search of a 19 tooth speedometer drive gear. White plastic, for my 64 Barracuda. I've tried Classic Ind, Year One, OPG, etc with no luck. Any suggestions appreciated.
Thanks, Darren
This is almost what you need, but the details are correct...:
"17 teeth (pale yellow-orange), marked D-177, max gear diameter .880. Only 1962 - 65 TF gears will work. Later gears are a different diameter..."
check Pat Blais Transmissions in WA. He did a write up on a mod and pointed this out. May know where to find one.
