Myasylum- Your first pic of the yoke, shows a low point on the left hand side. A light tapping with a rubber mallet and a light dab of grease would probably make it slide right in.
Supershafts post confirms a tight fit too as he has installed tons of these over the years.
Unfortunately so many parts are made overseas now and the fit and finish of OEM stuff is not what it used to be.
This has nothing to do with the oem.
Detroit was the oem company, detroit went OOB in the late 80's, spicer made replacements for the detroit 7260 series in greasables and when they went with the cold forged they only made crosses by the series THEY make, so that made the changes all at the cap.
The spicer spl line is stronger and slightly larger, spicer makes one cross for the 1300 series and makes up the lock up differences on the caps.
The larger cross simply needs a good tap and it pops into place.
I have installed these joints in my own shafts and hundreds and hundreds of customers shafts, all the 7260 series need the hit.
I use a ball-peen hammer and hit the cross and they're in, set the caps and clips and done.
The last company making joints in the US is spicer, the needles are made in VA and the caps and some crosses are made in the TN plant some truck crosses are made in Mex.
The plants are all over but they are spicer plants and not some china company coping **** and sending them out for a company.
The spl series will handle 700/800 hp in that series and even more.
