Spring re-location help (rear)
604 Racing
604 RACING
Vancouver, Canada
does anyone have info and pics on the M/P spring relocation kit,
im looking to do mine right now, and id like to see pics with tire sze and rim backspacing included
also, if you move the spring perches can you please provide me with accurate measurement.
my car is a 1971 dart
thanks.
The kit should have a paper with it on some details on doing this. I use the old front mount spring mounts to put the hole in the right spot. I tried to keep my springs centered on the frame with the rear mounting points before I welded everything. the rear mounts are using the 1" holes in the frame. i f you go to S/S springs, you have to move the right side forward a 1". I had to do this on 2 cars.
