67autocross
A new iron curtain drawn across the 49th parallel
My tires rubbed on the top of the fender on one side and I had to take out the bolts that are at the back if the fenders to the inner apron. You might have to loosen all the fender bolts and move the whole fender around a bit to make them fit worse case. Also adding camber helps with the contact at the top lip of the fender.
