Square Bore VS. Square Bore
Bodyperson
Pedal to the metal
NW MONTANA
I did not realize there was a difference until I bought a new Edelbrock AVS. It does not fit my manifold like I thought it would. Pics to follow.
I do realize a thicker insulating gasket and or a spacer that I will use will solve the clearance issue and I'm fine with that. I'm not trying to set the world on fire with this mild 340 build.
My question is... Should I live with the difference or should I mill out (gasket match) the offending aluminum? I still plan on using an insulator.
P.S. I have some experience with burr tooling.
I'd get a used 4 hole spacer and use WD-40 and a hole saw and open up the primaries on that aluminum intake.
You should use the correct gasket for the intake and that ain't it.
Something like this:
Thats a very good idea. I'm just wondering if I should just get a cheap speedmaster instead of hacking up what I think is a rare manifold.
Only you can answer that one brother. I would get exactly what you want, or you will always be wanting. Most any aftermarket intake would accommodate that 800 AVS2.
I always like to use a 1/2" phenolic spacer on all of my engines even if stockish. Personally I would blend it until the throttle blades fully clear.
It's not that rare of an intake and it won't hurt the value in my book.
Tom
Five minutes with a burr would fix the problem, no spacer needed. The man is designed to take a 750 AFB carb, which has 1 11/16" t/bores. The 800 AVS is slightly larger at 1 3/4" or.......1/16" bigger....which is 1/32" bigger at the man openings. So only a very small amount of metal needs to be removed....hardly 'hacking up' the intake or removing enough metal to change the flow characteristics.
I agree. It isn't much. Thanks for the responses folks.
So I got my spacer. Edelbrock wooden heat insulator. It has a divider like the 2 plane. I'm surprised it came with 2 open gaskets, I'd think the bottom gasket should include a divider too. Am I nucking futz?
Not an issue, it might like it. I would buy an open spacer and see if it likes it. Be careful with hood clearance. 1/2” can be significant. 1/4” would solve your original issue, if it has clearance issues.
I will be sure to watch the hood clearance. Learned that one 40 years ago when we changed manifolds on my buddies Camaro. Seen a lot of hood dimples since then lol. I'm going to clearance the intake for the carb any way so I can always revert to no spacer or try a smaller open one or something. Thanks.
Do you have a wood router? If you do, you can easily do a very professional job enlarging the intake using the spacer you have as a guide for a route bit.
Use the tool of your choice (die grinder with a sanding roll would get it done, eventually) and gasket match the intake.
Then you can run the spacer... or not.
Just what I would do.
(Thought at first it was core shift on an edelbrock. I have a Sixpack intake with horrible core shift).
Edit: uh, nevermind. Just read op's post #14. Problem solved.
Just use the gasket I recommended early on and it will work fine. But fack no you gotta hack the intake up. Makes no damn sense at all. Have at it.
I don't HAVE to hack it up. That was the question I originally asked. Most say yes and you say no. I didn't notice that the gasket you suggested was that thick and insulated. I should have looked closer. BTW, I like hacking manifolds so I'll still do it either way. Certainly cant hurt.
I just don't like making premanent modifications whe I don't have to. ....and you clearly don't have to. But hey, it's your intake.
