square to spreadbore adapter wanted
Try laying a spreadbore gasket on your intake and seeing if there's enough meat to grind out clearance so you won't need a poorly performing adaptor. Won't cost you anything but a little elbow grease. Also compare the gasket to your carb, its probably bigger than the throttle bores.
