Squeaking
68Abody
Member
My 68 dart has started to squeak loudly from the front end when getting in or out of the car ( I only way 180lbs : ) ), going around corners, going over bumps & if I push down on the front end. Any ideas on how to fix this problem? Thanks all.:yawinkle:
The front end rubber bushings are probably dried up and shot so they need to be replaced and possibly the balljoints and the other front end wear parts.
IF you have poly bushings installed they also will tend to squeak and you might need to lube them with something, or some folks will add a grease cert as the things are pretty hard and will take one I guess.
Mopars are famous for making noise like that when they get old, so do many other old cars when all those parts are worn out and dried up.
