SS leaf spring shackle bushing info needed
75 Duster 360
High Point NC
I have a set.of Mopar SS leaf springs on my Duster and I need to install new rear shackle bushings. I installed these about 10 years ago and I remember encountering a problem with the shackle bushings. The SS springs for an A body uses the B and E body larger size shackle which doesn't mate with the smaller A body rear shackle mount. Does anyone make a bushing for this combo or does anyone make an A body rear shackle mount that will accept the larger sized B and E body shackle? I used the A body bushings and reamed the top bushings out so that the larger shackle would fit.
Energy suspension 2-2117G. They go from an A-body shackle to a 1" spring eye. I used them to install a set of AFCO springs on my Duster, same problem with a 1" rear spring eye.
