1957guy
1957guy
Can anyone recommend a late model gear reduction starter for a 1965 Slant with A/T ?
All Mopar starters are the same regardless of motor
All Mopar starters are the same regardless of motor, including the newer style mini starters from Dakota pickups!! I would look into getting one of those, you can get them at the auto parts, or at most pick a part yards!!
Thanks for the accurate information ….WaltThat is not correct. Interchange on RWD/4WD starters is most (not all) '62-'89 RWD Slant-6 and V8 passenger cars, many (not all) '62-'01 Dodge trucks and RWD/4WD vans with Slant-6, V8, or 3.9 V6, and '05-'08 Dodge Ram trucks with 5.7 V8 and manual transmission. Exclusions from the "many/most" groups include trucks and cars with 11" clutch, '62-'66 Canadian-built Slant-6 cars and trucks, and pre-'70 cars with 426 engines.
Trucks and vans newer than '02 (except the '05-'08 manual-trans 5.7 Rams) have no nose cone on the starter, so they don't work properly on older applications that require the nose cone.
'89 was the first year for the Nippondenso mini starter. In '94 that starter was redesigned and got even smaller. The '05-'08 manual 5.7 Rams use an even more compact starter, a totally different (non-Denso) design.
I tried one of those mini-starters on my car and it didn't fit ('67 Dart, 225). Wouldn't line up...solenoid was on the inside and hit the block. Looked like it would fit an 8, but not a slant.
