larry408
I finally have the motoe back in my 73 Sport. I am not getting any fire through the coil wire. I have installed a new coil but it did not help. I was told that I need 9 volts across the + and - connectors on the coil. When I check with my ohm meter I am only getting 5.26 volts. When I jump the ballast resistor I am getting 7.75 volts. Do I need a new control box, ballast resistor or both?
