Good question and observation... I do not.... Even though I live in North Carolina and yes it can get cold, I garage the car and by the time I put the car into drive it's warm enough.....Do you need the use of the heated portion under the intake or not? (cooler climate)
You are correct... and guess what I’m doing now...? Replace the gasket....I would not use it at all. Because I'd rather not have to pull it apart when it is found to be leaking. You've got 3 leak paths there, air, oil, and water. Assuming this is a 318 or 340 motor, get some FelPro 1213S3 and do the job just once.
Complete fail... leaking water into the engine and a nice milky oil too boot...onto the thicker felpro gasket...
You’re absolutely correct....The problem with the steel shim gaskets are that they are too thin, in many cases. If the heads, block, or intake have been machined, or are not within tolerances (whatever they might be), that gasket is not going to seal. This is also why those cork end seals are usually too thick, and often can't be used on something that has been machined, or just isn't "right".
I did, but had a lot of machine work done.... weiand 8007 intake....
Pin gone... good questionWas there a "pin" in the middle of the front/rear "china wall"? Did you remove them?
bschubarg said:Complete fail... leaking water into the engine and a nice milky oil too boot.
I'm hard of hearing....""weiand 8007 intake""???....Did a bunch of us say to NOT use that shim gasket with an aluminum intake??????
That's not his problem...he used these shim gaskets with an aluminum intake against the advice of several people here. These are to be used with cast iron intakes only. Use composite (FelPro,etc.) ones with aluminum intakes.If you had your heads milled down, you should either have the intake surface of the head cut to match (so you can use any intake) or have the intake milled to match...either way, check fitment before gluing it down...my 0.02 dollars on the matter.
correct......That's not his problem...he used these shim gaskets with an aluminum intake against the advice of several people here. These are to be used with cast iron intakes only. Use composite (FelPro,etc.) ones with aluminum intakes.
