mopowers
Is there an "up" and "down" to steel shim head gaskets? I other words, do the ridges need to be oriented a certain way (up/down)? Thanks!
I think the locating pins govern that .
Thanks! That's what I was thinking. Just like the valley pan.Positive ridges go up towards the head.
It matters which way it goes to somebody.......
The reason it is marked is because it could be installed either way.
The dowels on a BB Mopar symmetrical.
The typical BBM composition gasket doesn’t have any markings to denote which is the top or bottom is because they can go on either way.
I have always silver painted them. KimNot all steel shim gaskets are marked, again it doesn't matter which way they are installed.
Head and block surfaces need to be flat and copper spray or silver paint on both sides.
