The factory installed gasket was the "shim" gasket. These gaskets have been NS1 for a few years, now. All the aftermarket head gaskets are the thicker type. When using an aftermarket gasket, you will lose a little compression. When replaceing a slant six head gasket, with an aftermarket gasket, it is desireable to mill the head, 10 to 20 thousands to put the compression back to factory.Wierd there was one on my 1975 pickup when I took the motor apart. I still have it.
That was my point. Why bother to pull a perfectly good head just to mill it to increase compression, only to give back a huge chunk of the gain to a crappy modern gasket?
