Steering box removal tricks?
superdart
Shade Tree Tinker Gnome.....
DFW, Texas
Ok, new question.....
I'm down to my two last parts for removal (I think):
Left side header and power steering box.....both are being a pain. Is there a trick to this? Both look they would come out easy were it not for the other. I am putting manual steering in, so I really don't care about the power unit.
Short of lifting the motor, is there a trick to getting these out? Just trying to avoid unbolting the motor if possible.
Depends on the header. I've had some that the mounts needed to be undone and the engine lifted with a jack and a piece of wood under the oil pan. Definitely don't envy you that job. have you removed the steering column? that might make it easier.
don
Well, I got it out, but it did require lifting the motor a few inches. It was pretty easy.
