Do you know if the switch light is lit when the headlights aren't on? Other than the engine running, nothing else was turned on or running.
- Speedometer, instrument cluster, brake light, high beam, oil pressure, turn signal (interior): #158
- Heater and a/c control: #1892
- Radio: #1893
- Transmission gear indicator, ashtray light: #161
- Reverse indicator (four-speed transmission): #53
- Ignition light: #1445
- Glove compartment: #1891
- Dome light, trunk and underhood lights: #1004
- Fasten seat belts, electric defroster switch: #1445
- Headlights: #6014
- Front turn signals, rear stop and turn signals: #1157
- Backup lights: #1156
- Rear license plate, fender-mounted turn signal indicators, side marker lights: #168
