Steering column identification
jawbone
Cuda_queer
Richardson, TX
Can someone identify this steering column. Intend to put it up for sale if it's deemed worthy.
Looks like a floor shift power steering column. Autos and 3 on the tree would have a moving lower arm out the bottom side and a lower moving bezel right below the key tumbler.
I’m interested in it. I have a wanted ad up. I’m looking for a floor shift, manual steering, but I might be able to the parts I have and this column work. Let me know.
This one does not have a integral key tumbler. Was building a steering column for a manual steer 68 Barracuda when this showed up. Cannot remember the details other than that. I do want to sell it but want to make sure I don't tell a fib in description. Let's see where the thread goes and we can talk again later.
It should be a 67-69 column since it has the collapsible section and no key. Hopefully another member can clarify if power steering or manual steering since shaft length determines
I agree on the manual. I just bought a similar column at a swap meet. Length of housing looks the same but center shaft only extends about 2" from there. My setup is likely to be manual steering, is there an extension available or do I have to switch the center shaft? Going into 68 Barracuda floor shift
Yes there is an extension available.
Mopar PS to MS Steering Box Adapter
