7374
ok so my steering column is acting really weird. somehow it is jammed with my column shifter and if i turn the wheel the shifter moves with it. it won't self "return" so i have to turn it back when you make a turn or go around a bend. i looked at it in the engine bay and see what appears to be a spring sticking out the bottom before it goes into the steering box. so somewhere the linkage is busted. has anyone had this problem before or does anyone have a detailed parts diagram of what is in the column and are parts available? thanks.
