Steering Column Mount Sleeve
RustyRatRod
Caput villa stultus
Georgia
On a 64 Valiant, three on the tree column. Does anyone know a source for the steering column mount sleeve that slides over the outside of the steering column that the column mount tightens against? Thank you drive through.
Hi Rob, Are you referring to either 19-14-10 or 19-14-35 ?
Kitty and I found something that will work fine, but I sure would like to find the right part if it's available.
Didn't you say electrical tape works fine for that?
It does. But this column has turned out so nice, I wanted the right part. We found something though. I've not been able to find it. I don't think it's reproduced.
