[WANTED] Steering column-power steering
69convertidart
Active Member
Princeton, NJ
Rating - 0%
0   0   0
Looking for a steering column from a 67-69 Dart or Barracuda with power steering and floor shift automatic. Converting my manual steering to power. Will consider trading my manual steering column for your power steering column.
I'm not saying this is the best way but... old school method was simply defeat the sheer pins and push the 2 piece shaft together approx' 3 inches, replace the manual steering box coupling with power steering size, done. If you're a stickler for safety aspects,,, to buy proper power steering shaft and coupling only will save on shipping. Helps afford new column bearings, coupling rebuild kit, etc...
