Steering Column Removal
GeorgeGerhard
Shelton, Ct
Hello all
I have enclosed some pics. In order to remove the steering column do I remove the 2 bolts on the smaller flange, or the three on the larger flange?
Also this car was automatic on the column at one time in its life. Now I will have a real problem removing the steering column as the shift linkage is interfering with the header tube. I dont even think I can get a sawzall in there to cut it off.
Another note I purchased a tool from American Muscle to remove the lower control arm bushing outer diameter shell. This tool worked perfectly, I had the sleeve out in 2 minutes.
Also I installed my upper control arm bushings, with a tool purchased from the same company
thank you for any advise
its cold here in Connecticut today
George Gerhard
remove the three bolts on the larger flange. the gear selector on the column will not fit through the firewall unless you remove the large flange.
