Steering Coupler Rebuild Kit for Early-A???
65Valiant310
Where is everyone purchasing their early-a steering coupler rebuild kits from?
I saw a kit on ebay, yet couldnt find one anywhere else for my 65
thanks for the help in advance
I just rebuilt my steering coupler on my 64 Dart the kit is available on ebay for 15.00 or go to your local mopar dealer it's still available part#4443436AC
hope this helps!
Vinnie
If you need header clearance, try using a "universal joint" style of coupler. Flaming river has a nice one but $$$$costly, others have this style in a much more realistic cost. Check CAP auto products, they specalize in "Early A body" front suspension parts. I know they have them in stock! Capautoproducts.com
thanks all
vinnie how hard was it to rebuild?
Not hard be sure you mark lines on the tube and steering gear so all lines up put it back together or your steering wheel will be off center.don't ask how I know!my center pin was froze on shaft so I took the colunm out of the car to press old center pin out of shaft be sure you watch how the 2 little shoes come off the center shaft thay are longer than they are wide so need put back on correctly or there will be alot of play in coupler!!!
Vinnie,
