steering coupler tightness
stoke
monroe, WI
How tight should the steering coupler be to the steering shaft, should it have any wiggle to it ? I cant seem to get it to be without movement I wouldnt think it should have any. But I dont know. You would think even a little movement would transfer to a lot at the steering wheel. Kind of a mickey mouse connection if you ask me. Thanks
You shouldn`t have any slop there. Kits are available to rebuild that joint from many vendors or you can replace it with a coupling from Flaming River. The FR joint is pricey but a nice improvement.
I forgot to say I have power steering. I have the repair kit in but it still has play. I cant believe that the shoe setup on the couplers could ever get real tight.
I got a new power steering unit but it is not not in yet. The column is out of the car and I am just prefitting everything before I put everything back together Do you think it will tighten up when I fill it up with grease and tighten the set screw?
The box will make a big difference if the old one was trashed. Are you sure the play is in the box/column or could it be further down the line in the pitman arm, tie rod ends, idler arm, etc.?
I just wanted to get everything as tight as possible before I put everything back in. Then I will go from there and check the rest of the suspension farther down the line. Guess I will just throw the power steering chuck and the column back in and see how it is all together we'll see how it goes, Thanks
I just found the problem, I had the shoes in the wrong way. Guess I should always try the obvious first. Looks like it should work well. Thanks Longgone for the input. Stoke
TE,TE EEEEEEE. Hey anyone that has worked on cars long enough throws a brain fart every now and then.
Now that I have the coupler tight , What order do they go back in ? Do you put the coupler on the power steering chuck, then install the column, or on the column first then push onto the chuck? thanks
Easiest way That I found is put the coupler on the column, then install it.
I put the coupler on the steering column first and then guide it on to the gear box. See if you can get a friend to help you orient the coupling in the correct position in the engine compartment while you work the column in to place inside the car.
