Nothing from a '72 model will bolt into your '64/5 except the steering gear and even there you may have to change fittings and/or custom build hoses depending on which pump you use.
That is what I am getting along with brackets and ps pump.
What engine do you have? If it's a 6cyl, get the add-on crank pulley with all the pump, brackets, and hoses. If it's a small block, the pump won't do you much good. All the pulleys and brackets changed between '69 and '70 and won't swap over without changing all the other brackets and pulleys on the engine along with the water pump, lower radiator hose, and radiator (or relocate the hose connection).
