dlistro1950
New Member
All,
I do not have an A body. However, I have a 1950 Ford Pickup that I have modified and installed a B body tortion bar front end. The truck has a g-3643311 With a R-25 embossed on it. It has a wide serpentine belt on a new Saginaw steering pump. I am finishing up a 10+ year restoration and I have some questions.
Q1 What cars would have a "R-25"?
Q2 What hose from the pump goes where. What's in and out on the pump and the gbox?
Q3 When I started the motor within a few minutes it looked like my garden hose sprung a pinhole leak. The gbox was squirting a stream of power steering fluid over 15 feet. I'm assuming when I pull the pump I'll need gaskets o rings etc. Where do I get the repair parts?
Thank you for any help you might be able to supply
Thank you,
Dick
Thank you,
Dick
