Steering Knuckle Needed
swerven11
Detroit, MI
Hi everyone bearing welded itself to spindle so i need a steering knuckle for my 73 dart passenger side disc brake setup large bolt pattern wheels Thanks
To designate caliper location desired will help insure you get the spindle you need. Either 11 oclock or 1 oclock . These part have benn stirred pretty well over the years.
You're probably gonna need a new boot for the lower ball joint too. I've never seperated one without destroying that boot. Hope this hekps. Good luck
It takes practice but I have smacked the knuckle with a bfh to seperate the steering parts to save the boot's. if you have bad aim don't try it LoL old timer at the track showed me that.leave the nut on there but loose in case you miss
I would have to agree with "waggin" i did automotive repair for 25 yrs and my speciality was front end, the bigger the hammer the better the separation!
Just dont miss or you hamburger------literally!
Ouch!
ase master
Doug
